| Version(s): | 10.00.00.120+ |
| Area: | Basic Settings |
| Original Author: | Marcus Blake, Bentley Technical Support Group |
There is a 'phantom element' my model file which I was using as part of a Point Control that is causing me problems. I can click on it in plan view, but it does not appear when I open Project Explorer. Selecting the element and using the delete element command doesn't erase the element. How can I get rid of it?
Here is an example below:
Additional resources on deleting levels found here: https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0112576
