To add the section from a existing file to the beam section library follow these steps:
- Open LEAP Bridge Concrete and open the file that has the missing beam section.
- Go to the Superstructure tab and launch Precast/Prestressed Girder module.
- You will get a prompt that the section could not be found in the library. Click on Yes to add to library
