| Version(s): | 08.05.01.25 | ||
| Area: | Text | ||
| Subarea: | General | ||
How to edit a piece of text through the key-in window without using the mouse to select a piece of text in MicroStation v8.
Use the key-in: CHOOSE ELEMENT;XY=,;EDIT TEXT.
*The Text Editor Style will have to be set to key-in if the text is to be edited only through the key-in.
