How to change template for multiple supports at the same time?
- To change templates for multiple supports at once select all the supports that need to be changed using the Element Selection tool:
- Click on Properties to open the Element Properties dialog
- Under Substructure Placement Rule select Substructure Template and click on "...":
- In the Substructure Template dialog click on "Switch Template" and select the desired template and click OK
