Troubleshooting Project Database Connection Problems
 Product(s):Promis.e, Bentley Substation
 Version(s):through 08.11.13.140
 Environment:SQL Server
 Area:Database Platform Support
 Subarea:N/A
Promis.e and Bentley Substation require a connection to a SQL project database in order to function.  If such a connection does not exist, an error message such as the following may be displayed:
The purpose of this document is to serve as a guide for troubleshooting these connection problems when SQL Server is the database server software used.  Oracle can be used as the database server software but is not covered in this article.
This document assumes that Microsoft SQL Server has been successfully installed.  If there was a problem during installation, please consult the documentation and web sites for SQL Server.
Some questions to keep in mind while troubleshooting connection problems or requesting technical support include:
Requirements for a successful connection:
Click the Apply button on the [[Setup]] dialog in Promis.e/Substation after making changes to see if a connection can be made.  A successful connection to the project database is indicated by no error message being returned.  The connection is confirmed by the ability to create new projects or open existing projects that are in the database specified on the [[Setup]] dialog.
For the remainder of this document, "the software" will refer to Promis.e and Bentley Substation
Steps to Resolve
The connection must be enabled on the Setup dialog
If everything was working and Promis.e/Substation projects could recently be opened and created by the workstation now encountering the problem, sometimes all that is necessary is to enable the appropriate radio button on the Project Database area of the [[Setup]] dialog.  If neither the “SQL Server/MSDE” nor the “Oracle” options are enabled, the software will not have a project database connection even if the remainder of the settings are valid.  Unless you know that you are using an Oracle server, enable the “SQL Server/MSDE” option.
The SQL Server software must be installed on the machine that is to host the SQL Server
This means that the Microsoft’s SQL Server installation files must be run on the machine that is to act as the server.  Running the installation files on a workstation will not install the software onto a network server machine.
An indication that SQL Server is installed is that a “Microsoft SQL Server...” program group exists in Start > Programs on the machine hosting the database.
The SQL Server version must be compatible with the Bentley software that is trying to connect. Refer to the compatibility chart for the software:
[[Compatibility Chart - Promis.e]]
[[Compatibility Chart - Bentley Substation]]
The login must be valid
Wrong login or password
Another common cause of connection problems is using the wrong SQL Server Authentication login or password, or the login does not even exist in SQL Server.
If the database was created automatically by the software the SQL login created may use the following credentials:
Login name: ecaduser
Password: Ecad1pass
The SqlServerProject.sql script from pre-SELECTseries 4 era software also created the above login.The SqlServerProject.sql script included with recent releases no longer creates this login.
If the SQL Server was originally installed via a promis.e 2007 v2.0.x installation file or CD, the password may be: ecadpassword
If the SQL Server that is to be used is installed by the user (not by an admin with a different Windows login), Windows Authentication can often be used instead of SQL Server Authentication and requires no password be entered on the [[Setup]] dialog.
It is possible that a database administrator (DBA) created another SQL login with a different name and/or password or created Windows logins for each user, allowing users to select Windows Authentication on the Setup dialog.  Contact the DBA for help in these situations.
Login does not exist
If the database was moved to a different server, the ecaduser login that may have once worked may need to be created again.
If the database was created using the SqlServerProject.sql for recent versions of the software, the SQL login will not exist or will not be associated with the database.
In these cases, see [[5824|Creating an SQL Server Login]].
SQL Server not configured for SQL Authentication
If the SQL Server is configured for Windows Authentication only, the following message can result when trying to connect with SQL Server Authentication:
"Login failed for user 'ecaduser'. The user is not associated with a trusted SQL Server connection. (Microsoft SQL Server, Error 18452)"
To be able to connect with SQL Server Authentication, the SQL server must be configured to use "SQL Server and Windows Authentication mode" instead of only "Windows Authentication mode".  To view or modify this setting, connect with SQL Server Management Studio (using Windows Authentication), right-click the server name in the Object Explorer, and select Properties > Security. If SQL Server Management Studio is not installed, see [[Install SQL Server Management Studio]].
The Server Name must be correct
In the Project Database area of the [[Setup]] dialog, the machine name of the computer hosting the project database should be entered into the Server Name field, followed by a backslash ( \ ) and then the SQL instance name:
SERVERMACHINENAME\INSTANCE
Note that using a forward slash will not work.
Standard and higher (non-Express) editions of SQL Server may not use an instance name.  In this case, only the machine name of the server should be entered into the Server Name field, with no backslash or instance name:
SERVERMACHINENAME
There should be no leading slashes before the machine name as if this was a UNC path.
When the SQL Server is located on the workstation, the text “(local)” can be substituted for the actual machine name.  In this case, the workstation is also acting as the server machine:
(local)\BENTLEYECAD
It is also possible, but not necessarily recommended, to use the IP address of the server in place of the server machine name:
192.168.1.106\BENTLEYECAD
The name of the SQL instance is most likely either BENTLEYECAD or ECTECAD if the SQL Server was installed via the Promis.e or Bentley Substation installation.  However, it could be the default name of SQLEXPRESS or whatever was specified during a standalone installation of SQL Server Express.
Instance names are not case sensitive.
To verify the names of the installed instance(s), on the server machine select Start > All Programs > Microsoft SQL Server xxxx > Configuration Tools > SQL Server Configuration Manager, where xxxx is the version such as "2005" or "2008".  In the configuration manager, click on "SQL Server Services" in the left pane and view the instance names in the right pane.
Specifying a Port
If a non-standard static port is used it is possible to specify the port used for connecting to the SQL Server instead of running the SQL Server Browser service on the server.  The format for the Server Name field on Setup is the Microsoft standard convention:
SERVERMACHINENAME\INSTANCE,PORT
For example:
ENGRSERVER\BENTLEYECAD,49170
Note there are no spaces between any of the elements and separators in what is specified for the Server Name field.
The SQL service must be running on the server machine
In single-user environments, the SQL Server hosting the project database is often installed on the user's workstation. Since the SQL Server service is set to start Automatically by default, rebooting the workstation often resolves the problem of a stopped service.
To determine if the service is running, select Start > Programs > Microsoft SQL Server xxxx > Configuration Tools > SQL Server Configuration Manager on the server machine.  In the configuration manager, click on SQL Server Services in the left pane and view the instance names in the right pane.   The SQL Service for the instance that the software uses must be running in order to connect to it.   If the service is stopped, right-click it and select Start.
If the service cannot be started (for example "The request failed or the service did not respond in a timely fashion"), open the ERRORLOG file with a text editor and look for an error number.  Search the internet for the error number/message.
The ERRORLOG file should be found in a path similar to one of the following:
C:\Program Files\Microsoft SQL Server\MSSQL10.BENTLEYECAD\MSSQL\Log\
C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\
If other machines are to connect to the SQL Server, use the SQL Server Configuration Manager to:
The database must exist and be attached to the SQL Server
The project database has a required structure.  An empty or arbitrarily created database cannot be used.  Scripts and front-end tools are provided for creating the project database on existing SQL Servers.  See the [[Creating and Updating the Project Database]] article.
The names of Promis.e project databases usually begin with "promise".
The names of Bentley Substation project databases usually begin with "Substation".
To determine what databases are attached to the SQL Server, start Microsoft SQL Server Management Studio (SSMS) on the server machine and connect.  Look in the Databases “folder” in the Object Explorer to determine the name of the database(s). If SQL Server Management Studio is not installed, see [[Install SQL Server Management Studio]].
If there is more than one instance, connect to the various instances and look for the project databases.  Note the name of the database and the instance it was found in and use these on [[Setup]] > Project Database.
Alternatively, search for the .mdf and .ldf files that constitute SQL databases on the machine hosting the SQL Server.  This method does not indicate if the databases are attached, however.
For SQL Server 2014 the files are often located in a path similar to
         C:\Program Files (x86)\Microsoft SQL Server\MSSQL12.BENTLEYECAD\MSSQL\DATA
For SQL Server 2008, a typical path is:
C:\Program Files (x86)\Microsoft SQL Server\MSSQL10.BENTLEYECAD\MSSQL\DATA
For SQL Server 2005, a typical path is:
C:\Program Files (x86)\Microsoft SQL Server\MSSQL.1\MSSQL\Data
For example, files named promise2.mdf and promise2_log.ldf indicate a database named “promise2”.
After determining the database name(s), try specifying it on [[Setup]] > Project Database.
If the data files for the project database exist but the database does not appear in the Object Explorer in SSMS, try attaching the database to the server.  In SSMS, right-click the Databases folder in Object Explorer and select Attach.
The data files for the database must not be compressed
One indication that a file is compressed is that the text of the file name appears blue in Windows Explorer:
Compressed "promise" database files
Disk clean-up utilities have been known to compress SQL database files.  A database with compressed datafiles can appear in the Object Explorer of SSMSE with no "subfolders" within it.  To decompress the files:
  1. Stop the SQL Service using SQL Server Configuration Manager
  2. Select the files in Windows Explorer
  3. Right-click the selection and select Properties
  4. Click the Advanced button
  5. Disable the “Compress contents to save disk space” check box, click OK
  6. Click OK to exit the Properties dialog
  7. Start the SQL Service using SQL Server Configuration Manager
The Server Must Be Configured for Remote Connections
If the SQL Server hosting the project database is running on a different machine than the workstation, the server machine must be configured to allow remote connections.  This often entails
See the links below for more information
SQL Server 2014
How to enable remote connections in SQL Server 2014?
https://technet.microsoft.com/en-us/library/ms191464(v=sql.120).aspx
Configuring the Windows Firewall to Allow SQL Server Access
https://msdn.microsoft.com/en-us/library/cc646023(v=sql.120).aspx
Configuring a Fixed Port
https://technet.microsoft.com/en-us/library/ms177440(v=sql.120).aspx
SQL Server Browser Service
https://msdn.microsoft.com/en-us/library/ms181087(v=sql.120).aspx
SQL Server 2008
How to enable remote connections in SQL Server 2008?
http://blogs.msdn.com/b/walzenbach/archive/2010/04/14/how-to-enable-remote-connections-in-sql-server-2008.aspx
http://msdn.microsoft.com/en-us/library/cc646023%28v=sql.105%29.aspx
http://msdn.microsoft.com/en-us/library/ms345327%28v=sql.100%29.aspx
http://msdn.microsoft.com/en-us/library/ms181087%28v=sql.105%29.aspx
SQL Server 2005 (not compatible with recent versions of Promis.e and Bentley Substation)
How to configure SQL Server 2005 to allow remote connections
http://support.microsoft.com/kb/914277
How to: Configure a Firewall for SQL Server Access
http://msdn.microsoft.com/en-us/library/ms175043%28v=sql.90%29.aspx
http://technet.microsoft.com/en-us/library/ms345327%28v=sql.90%29.aspx
Other Notes
If problems persist, try connecting to the SQL Server using SQL Server Management Studio (SSMS) from the workstation using the same credentials as being used on the Setup dialog. This may provide a more verbose error message that can be then investigated further. Generally, the settings used to successfully connect via SSMS can be used on [[Setup]] > Project Database.
SQL Server Management Studio is backward compatible, meaning SSMS 2014 can manage SQL Server 2008, but SSMS 2008 cannot connect to SQL Server 2014.
SSMS is not included with Promis.e and Bentley Substation packages that include SQL Server 2014 Express. See [[Install SQL Server Management Studio]].
Promis.e and Bentley Substation use the .NET provider to connect to the SQL Server project database, so some connection issues can be caused by corruption of the .NET Framework.
[[Creating an SQL Server Login]]
[[Compatibility Chart - promis.e]]
 Original Author:Matt_P
