In KeyLAB a test is a set of components. it's very important to understand this when trying to modify or import a test into KeyLAB.
The guide below shows the four components,
The components are;
You can import all of these components by following the guide linked below.
You can also get a test out of KeyLAB with a complete export which will export all the four components
