| Product: | MicroStation | |
| Version: | 08.11.09.459 | |
| Environment: | N\A | |
| Area: | Coordinate Systems | |
| Subarea: | General | |
Problem Description
How to import x,y,z points from a text or CSV format file, specifying either the use of labels or text at those imported positions.
1. Open a 3D file
2. Use the Tool XYZ Text\Import coordinates
![](77dcf7bc4775c2909091861f536d4303.iix)
Note: Available from Tool Menu\Tool boxes
3. Select import coordinates
4. Press Browse and navigate to the directory where we have the text file with the coordinates
Note: The format must be something like what is shown in the image below (X, Y, Z coordinates). If you file has just X and Y values, you need to add a value to Z, for example Z=0
5. Select this file and then press process
This will introduce the coordinates (points).
It is recommended to change the active line weight and also color to make them more easily visible.
6. To introduce the labels or Text you need to use the application pltpnt.ma
You can download it from here
pltpnt.ma to place text at specific coordinates
7. Save it in the default directory C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\mdlapps
8. Go to Utilities menu\ MDL applicacions
9. Select Browse button and select pltpnt.ma
This will launch a dialog like this
10. You can use the default values or change the color and Xoffset, Yoffset or just select the file directly
Note: this text file needs to has the following format (label name or text with blank spaces and,x,y,z)
![](f6ec37781bf58a90f3fc5287624bcb19.iix)
this will introduce the labels or text
![](4fecffbc4775c2909091861f536d4309.iix)
![](6fec7ffc4775c2909091861f536d430b.iix)
Other Languages sources
Español, Français, Deutsch
![](8cfcbbfc4775c2909091861f536d43d7.iix)
| Original Author: | Maria Munoz | |
