| Version(s): | through 08.11.13.140 | ||
| Area: | Project Management | ||
| Subarea: | Project Manager |
When [[Project Manager]] is opened, a big red X appears over the folder tree pane, and an error message is displayed.
Project Manager
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Index was outside the bounds of the array
or
Project Manager
Object reference not set to an instance of an object.
Pages in the currently selected project can be accessed, but no other projects can be selected.
If the Reset button does not help or is not available, do the following.
Close Promis.e or Bentley Substation.
Delete or rename the following folder
[[Application Data (per-user configuration) - Promis.e]]
[[Application Data (per-user configuration) - Substation]]
| Original Author: | Matt_P |
Keywords: System.NullReferenceException: Object reference not set to an instance of an object. at DevExpress.XtraBars.Docking.Paint.HideBarPainter.DrawHideBarControlButtonContent
