| | Product(s): | MicroStation | |
| | Version(s): | 08.11.09.459 | |
| | Environment: | N\A | |
| | Area: | Configuration | |
| | Subarea: | Workspaces | |
What is the difference between the Workspace "System" and "Standards" directory?
They have a similar structure of the subdirectories, however, the "Standards" directory are blank during a new installation.
Why?
The "WorkSpace"-directory
In the Workspace directory, users create and manage standards and projects in a network environment.
User data files should be stored in the WorkSpace directory or on a network drive to share project data, develop,
manage, and enforce drawing standards, and set the product's appearance on the desktop.
The WorkSpace-directory contains the following:
- The "System" directory, updated by Bentley.
Any user data stored in this directory will be overwritten in future updates or new installations. - The "Standards" directory, where the CAD-Manager or System Administrator stores ad manages company-wide standard configurations.
Project data that can be used for multiple projects can be moved to this directory. - The "Project" directory, in which project-specific data are usually stored.
- The "Users" directory, where user configuration files are stored for the use of workspaces.
- The "Interfaces" directory, where the workspace interfaces are stored.
Users can create projects using the default naming convention.
If the configuration variable _USTN_WORKSPACEROOT are set, the files can be installed at any location on the network before starting the project.
For details, please read this wiki:
Networking Workspaces the easy way
Details
The directory "..\WorkSpace\System" contains the Bentley Standards.
Do not create user data in this directory.
This directory also has the following subdirectories / files:
- Borders - Bentley standard sample borders
- Cell - Bentley standard cell libraries (e.g. for hatching, sampling, light sources, etc.)
- Colorbooks - Bentley standard system colour books
- Data - Bentley standard data files
- Database - Bentley standard database files
- Dgnlib - Bentley standard DGN library files
ClashDetection.dgnlib - contains the display styles for the representation of collisions and other settings of the collision check.
DrawingSeed.dgnlib - contains the default drawing seeds, the display styles, and the detail icon styles needed to create drawings.
LinkSetSeed.dgnlib - contains the default linking group.
LuxologyRender.dgnlib - contains the render settings and the environment settings.
ModelTransparency.dgnlib - contains the display style for the model transparency.
NamedExpressions.dgnlib - contains named expressions that are used to retrieve values from application data structures and application data properties
PageLayout.dgnlib - contains the resources needed to create markup templates and markup-named expressions. - Fonts - Bentley standard fonts and font configuration file "MstnFontConfig.xml"
- GUI - Bentley standard GUI library files
GUI.dgnlib - contains the tasks, main task, and context menus that are delivered with the product.
VectorIcon.dgnlib - contains the resources needed to create vector symbols. - Image - Bentley standard icon image files
- macros - Bentley standard macro's
- materials - Bentley standard materials
- Menus - Bentley standard tablet menu's and related data
- pltcfg - Bentley standard printer driver configuration files
- seed - Bentley standard drawing seed files
- Symb - Bentley standard symbol files (RSC line types and RSC fonts)
- tables - Bentley standard table files
- Vba - Bentley standard Visual Basic files
The directory "..\WorkSpace\Standards" contains Corporate Standards.
- cell – Corporate standard cell libraries (shared among projects)
- data – Corporate standard data files (shared among projects)
- dgn – Corporate standard DGN files (shared among projects)
- dgnlib – Corporate standard DGN library files (shared among projects)
- macros – Corporate standard macro's (shared among projects)
- materials – Corporate standard materials (shared among projects)
- mdlapps – Corporate standard MDL applications (shared among projects)
- pltcfg – Corporate standard plot driver configuration files (shared among projects)
- seed – Corporate standard seed files (shared among projects)
- spc – Default location of security configuration variables
- symb – Corporate standard symb files (shared among projects)
- tables – Corporate standard table files (collectively used for projects)
- vba – Visual Basic files
Standard configuration file
The standards configuration file "standards.cfg" is used to store company-wide configurations and configurations that can be used for multiple projects.
They are usually set by the system or site manager. These configurations include: the search paths for cell libraries, Settings Manager files, DGN files, macros, seed files, material palettes, pattern maps, and bump maps; the directories for new cell libraries, new cell selector files, and new Settings Manager files; and the list of symbology resource files.
The standards configuration file is found in the directory defined by the _USTN_SITE configuration variable. The default location is in Bentley's "..\WorkSpace\Standards" directory
The directory "..\WorkSpace\Interfaces" has the following subdirectories:
- Buttons – button menu's
- Fkeys – Function key menu's
- MicroStation – (default)
- MicroStation \default – (default)
See also
Other language sources
Der Unterschied zwischen Workspace System und Standards Verzeichnissen
| | Original Author: | Rene vandenBrink | |
