| Version(s): | 08.05.00.64 | ||
| Area: | Detailing Symbols | ||
| Subarea: | XYZ Text | ||
Label Point Coordinates are using ACS.
When using the Label Point Coordinates, the wrong coordinates are placed in the design file. The status bar (Coordinate Readout) displays the correct values. How to set Label Coordinates to use ACS coordinates.
Starting with MicroStation 2004 Edition it is possible for Label Point Coordinates to use ACS Coordinate systems. This is the default mode.
The key-in to change the mode is:
Key-in: LABEL USEACS [ON|OFF|TOGGLE]
