Conversion of LARS .bmd file to LARSBridge .lrs file.
Document Information
Document Type: FAQ
Product(s): LARSBridge
Version(s): All
QUESTION: Conversion-- How to convert LARS .bmd file to LARSBridge .lrs file?
ANSWER:
Please follow this procedure to import the LARS bmd file to LARSBridge .Lrs file.
Start the LARSBridge program and Click on OPEN button and then go to concerned folder where the LARS bmd file is located.
Select the “Old LARS Bridge Files(*.bmd*)” option and then select the concerned .BMD file and then click on OPEN option.
Then after few seconds the program will show a warning message saying, “CONVERSION SUCCESSFUL”.
Next step is to click OK, then the program will generate a complete bridge model with superstructure and substructure information which are based on some predefined conditions set internally in the program.
