How to Add Superelevation to a Civil Cell
Version(s):08.11.09+
Area: Civil Cells
Question:
What the best practice for creating superelevation through the civil cell?
Answer:
Superelevation is only applied to corridors. If a corridor is included in a civil cell, superelevation can be applied after placement. Otherwise, you will need to use a geometry rule application.
