| Version: | V8i, CONNECT | ||
| Area: | Printing | ||
| Subarea: | Driver/PDF |
How to create a GeoPDF
Go to File>Print>Select Printer driver configuration files
Select Pdf.pltcfg
Press OK
Select File>Edit printer driver configuration
Select the Base Properties tab and go to the Driver properties
Enable Georeferencing Select ON
File save.
The option to create and print a Geopdf has now been enabled.
How to make a PDF of your design file
Castellano , Français , Deutsch
| Original Author: | Maria Munoz |
