Product(s): | OpenRoads Designer, InRoads, MX, GEOPAK |
Version(s): | 10.00.01.15+ 08.11.09+ |
Area: | Templates |
Question:
What is the order in which template data is processed at each template drop?
Answer:
This is generally the order in which OpenRoads solves the location of points and components at each template drop...
- Template is dropped, and points are placed according to the point constraints stored in the template.
- Parametric constraints are applied as defined in the template, and in the corridor.
- Horizontal Feature constraints are applied to move points if the feature is found in the specified range.
- Point controls are applied to the assigned points, overriding the corresponding constraint, and all points that are constrained back to the point controlled point will be recalculated.
- Component display rules are solved based on the current position of all points.
- End conditions are solved by extending designated segments along the specified slope to seek their targets.
![](9083b36697758e10afb952800153af72.iix)
