Product: |
Assetwise Information Integrity Server (AIIS) Product ID 1900 Assetwise ALIM Web Product ID 2907 | |
Version(s): | All | |
Environment: | N/A | |
Area: | ALIM Import/Export Tool | |
Subarea: | N/A |
ALIM Import/Export utility Role-Persons tab not functioning properly. Data will not import, producing "Error: Object reference not set to an instance of an object."
The Object Type in provisioning.xml has a non existing Type (Role-Person). It should use "Role" type.
Look into Provisioning.xml and search for “Role-Persons” section. Then change the object type from “RolePersons” to “Role”, save provisioning file and try the Import again:
<sheet name="Role-Persons" header_row="1" start_row="2" state_column_name="Status" message_column_name="Error Message" export_enabled="true">
<objects>
<object type="Role">
<properties>
<property name="path" column_name="Role Path" />
<property name="person" column_name="Person Code" />
<property name="action" column_name="Action" />
</properties>
</object>
</objects>
</sheet>
