| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Wave Load case |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
Is there another way to define current lift coefficient other than using "Insert> Xtra Data> Hydrodynamic data"?
The Lift coefficient for all points is assumed zero unless identified by Insert> Xtra Data>Hydrodynamic Data.
