| Version(s): | through 08.11.13.140 | ||
| Area: | N/A | ||
| Subarea: | N/A |
How do I bring up the Tutorial if I always start with the Project Manager so that the Welcome screen no longer appears?
In Promis.e V8i Standalone and Bentley Substation V8i
Select Help > Show Welcome Dialog
In promis.e V8i for AutoCAD
Select promis-e|Help > Show Welcome Dialog
Browse to and open the PDF file for the desired tutorial using PDF reader software.
Promis.e
The tutorials are found in a "Help" subfolder of the [[Program folder - promis.e|Program folder]]. A typical path is:
C:\Program Files (x86)\Bentley\promise V8i\Promise\Promise\help
The tutorial files are named
Promis-e_ANSI-IEEE_tutorial.pdf
Promis-e_IEC_tutorial.pdf
Substation
The tutorials are found in a "Help" subfolder of the [[Program Folder - Substation|Program folder]]. A typical path is:
C:\Program Files (x86)\Bentley\Substation V8i\Substation\Promise\help
Substation_ANSI-IEEE_tutorial.pdf
Substation_IEC_tutorial.pdf
