Structure Model - Additional Check points
Document Information
Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
QUESTION: In the Structure Model to add additional check points, what does p, f indicates ?
ANSWER:
In Structure Model ,
P represents the PLASTIC HINGE LOCATIONS -->
                              @ COLUMN TOP --> Cap Column joint
                              @ COLUMN BOTTOM  --> Column base.
F represents the Flexural/Shear CAP Design -->  @ FACE OF SUPPORT.
