Video: Stack Cross Sections on Sheet from Top to Bottom
Product(s):OpenRoads Designer
Version(s):10.08.01.33+
Area: Drawing Production
This video demonstrates using OpenRoads Designer to create a cross section set which stacks cross sections on your sheet starting at the top of the page moving downward.
Note: For 10.08.01.33, it is required to have a sheet seed with the first boundary on top, however, beginning in the 10.09 release, a separate sheet seed for top-down will not be necessary.
Set variables CIVIL_CROSSSECTION_STACK_TOP_DOWN = 1 and CIVIL_CROSSSECTION_BOT_MARGIN to your bottom margin value.
  www.youtube.com/watch
