How to Test Concrete Cubes and Cores in KeyLAB
Introduction
Testing concrete cubes in KeyLAB works just as any testing in KeyLAB. The video guide below will run over the process of adding the cubes or cores and scheduling them. It will also show how to access them as a test along with how to report them using the test report interface.
https://vimeo.com/585300113
Set up Concrete Testing
Setting up concrete tests requires a couple of steps to make sure you have everything working. the first will be to import the test definition for the cube or core tests. This is covered in another guide.
Guides for setting up new Test Definitions
The following video will take you over the steps for setting up the system for cubes. along with adding additional days for testing.
https://vimeo.com/585301707
