Product(s): | ProConcrete | ||
Version(s): | CONNECT Edition (10.xx.00.xx) | ||
Environment: | N/A | ||
Area: | Rebar Display | ||
Subarea: | N/A | ||
Original Author: | Kemuel Jancorda, User Success Team |
There are instances when applying lap splice to a rebar set. Rebars are overlapping with each other without any offset or crank.
This scenario happens when the Rebar Display options for laps are set to line. To set the laps to cranks,
This option will allow you to display laps as cranks on your 3D Model. You may also opt to display the laps as a Line depending on your preference. Please take note that the Rebar Display options are set for viewing purposes only and will not affect the Structural properties and configurations of the rebars.
