| Product(s): | InRoads | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Question:
How do I generate a report or listing for several of the Roadway Designer screens such as template drops, point controls, template views, etc?
Solution: Within Roadway Designer, select Tools>Results Report, Select your desired Corridor and points to
Report At. Within Bentley Civil Report Brower, Select the Roadway Design Leaf, you have a few options as to your report format but you may want to start with RaodwaySetup.xsl.
