Creating gINT Civil Tools Cross Sections, managing the direction
When creating a Cross Section, the data is projected on the 2d model left to right using the line direction. The first point of the line ( or SmartLine ) defines the left of the 2d model; and the last point defines the right.
If the line you are using does not have the right direction, you can change it
