| Version(s): | ALL | ||
| Area: | Import | ||
When attempting to import an AutoPLANT PXF file, the following error occurs and crashes AutoPIPE:
Intel(r) Visual Fortran run-time error
forrtl: severe (59): list-directed I/O syntax error, unit -5, file Internal List-Directed Read
The issue involes the tag numbers. Lines beginning with "2063 $" are the cause of the problem. AutoPIPE treats commands with $ specially.
Open the file in a text editor such as Notepad, and use the Find/Replace functionality to replace any instance of
2063 $
with
2063 $
To clarify, add one more space between 3 and $.
It is easier to do that on the merged PXF file.
[[Table of Contents - AutoPIPE Wiki Page]]
