| Version(s): | CONNECT |
| Area: | Workspace |
Question:
How do I find the active location of your Workspace and Workset?
Go to File > Settings > About > About Configuration. The about Configuration window opens, displaying information about the active WorkSpace and its components. The path to each component appears below the component’s name. If you cannot see the complete path to a component, point your cursor at the path and the complete path appears in a tooltip.
