Applies To | |
Product(s): | AutoPIPE Vessel |
Version(s): | V8i |
Environment: | N/A |
Area: | Warning Message |
Original Author: | Bentley Technical Support Group |
Date Logged & Current Version | April. 2016 40.02.00.08 |
When trying to create a drawing file from AutoPIPE Vessel V8i 33.01.00.11, the following warning message is displayed:
Probes : Views not fully filled : Pressure vessel Vertical A1
Probes : Views not fully filled : Views : 0009 : Header block name : NHNOHT : Iteration block name : NLNOHT ...
How to avoid this issues and fix it?
The CAE development team is investigating the issue. more will be posted as the information is received.
