This functionality is only present in builds prior to the 1.34.x releases. Anything after 1.30.3.x now has a new Office creation facility.
The appearance of the company address on any quick logs and sections may be defined within the configuration section of the project to allow for different values to be added to different projects when needed. To edit the company address, select the Company Address option from the Configuration section of the ribbon.
The new details can then be entered into the box as needed.
