| Version(s): | 08.09.04.88 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How do you use wildcards in a MicroStation pen table to specify several reference file logical names?
In the "Modify Pen Table" menu, select "Files", then in the Reference Logical Name field, use a ".*" before or after the string you want to wildcard.
Examples:
.*gray.* - to find all reference files with the word "gray" in it
gray.* - to find all reference files beginning with the word
"gray"
.*gray - to find all reference files ending with the word "gray"
