| Product(s): | ProConcrete | ||
| Version(s): | CONNECT Edition (10.xx.00.xx) | ||
| Area: | Plotting | ||
| Subarea: | Rebar Colors | ||
| Original Author: | Kemuel Jancorda, Bentley Product Advantage Group |
User wants to plot rebar level colors from 3D Rebar Elements to Plotting Sheets. Even though Display Rules are set, user reported that colors are missing as displayed in the Print Preview and in the sheet output.
In the References dialog under 2D Drawing models, Synchronize View settings may be set to "Settings from the Design Model".
It is recommended to modify the abovementioned settings to resolve the issue.
