Product(s): | promis.e V8i | ||
Version(s): | through 08.11.12.137 | ||
Environment: | N/A | ||
Area: | Migration | ||
Subarea: | N/A |
Once you install the new promis.e V8i version, you will probably want to be able to use your existing customized legacy data in the new version. This is done in various ways, depending on the version you are starting from. If you do not have custom data, then you should be able to use the standard built-in symbol catalogs and page formats, etc. You only need to migrate things that you have changed from the original. A general rule is that you should migrate all supporting items, like catalogs and page formats before you migrate the projects. If you do not, then you could get inconsistent results.
promis.e V8i SELECTseries 7 (08.11.12.137) is the last version to include the ability to migrate data from promis.e 5.0x, Aero, and Aero II.
If you have promis.e 2007 3.0.1 - 3.0.3, you have the option of doing an upgrade install of promis.e V8i over your existing version. If you choose this option, then there is nothing to migrate, as the upgrade install does it for you. You should be able to simply open your existing projects and begin working.
If you do a new install of promis.e V8i instead, or are switching from an AutoCAD based version to a MicroStation-based version, then you do have to migrate your legacy data. For projects, this consists of using the [[Project Manager]] to back up the existing projects in the legacy 2007 3.x version (be sure to check the box to save in MicroStation compatible format if switching to that version) and then restore them in the new promis.e V8i version. (Note: you must use a V8i version of MicroStation or MicroStation PowerDraft to migrate projects. An XM or older version will not work.) For catalogs, you would only need to migrate them if you were switching from an AutoCAD based version to a MicroStation-based version. If you are, then you will need to use the [[Migration Wizard]], and select the radio button for migrating from AutoCAD to MicroStation.
Information on how to use the [[Migration Wizard]] can be found in the system manual or [[promis-e Help file|promis.e help]] dialogs. Page formats are also migrated using the same migration wizard setting.
To migrate legacy data from this version, you will need to use the [[Migration Wizard]] as described above, but this time select "From promis.e Version 2.0". You will need to use this wizard to migrate custom symbol catalogs, page formats and parts databases. Follow the steps in the wizard, or look in the system manual for help on this feature. To migrate projects from promis.e version 2.x to promis.e V8i, you should use the Project Manager to back up the existing projects in the legacy 2.x version (be sure to check the box to save in MicroStation compatible format if switching to that version) and then restore them in the new promis.e V8i version. (Note: you must use a V8i version of MicroStation or MicroStation PowerDraft to migrate projects. An XM or older version will not work.) If you are changing from version 2.x and also switching from AutoCAD to MicroStation format, then your catalog files will need to be migrated twice, once using the setting from v2.0, and then that resulting file will need to be migrated using the setting for converting from AutoCAD to MicroStation format.
To migrate legacy data from any of these versions, you will need to use the [[Migration Wizard]] as described above, but this time select "From Legacy promis-e". You will need to use this wizard to migrate custom symbol catalogs, page formats, language files, parts databases, and projects. Follow the steps in the wizard, or select the Help button on the dialog for more information.
If you have projects that were created in older versions of promis.e than the ones mentioned above, then you will need to first update them to promis.e version 5.05 or 5.06, then you can migrate them as described above into promis.e V8i. Please contact your sales manager for questions with this.
[[3596|Migration Tips and Tricks]]
[[Moving From promis.e for AutoCAD to promis.e Standalone]]
Original Author: | Tani_S |
