| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import / Export |
| Date Logged & Current Version | Oct. 2016 10.01.00.09 |
Can AutoPIPE Import Bentley Microstation model information?
At this time there no direct export from Microstation to AutoPIPE. Select one of the following options:
1. Export Microstation file to PlantSPACE and then from PlantSPACE to AutoPIPE.
OR
2. One of the modules that sit atop of Microstation may be able to export center-line coordinates to Excel and then import the Excel file into AutoPIPE.
