| Product(s): | Promis.e CONNECT Edition | ||
| Version(s): | 10.00.XX.XX to 10.09.XX.XX | ||
| Environment: | NA | ||
| Area: | Component Management | ||
| Subarea: | Catalog Manager |
Using the Export Catalog Feature you can make backup of Catalogs that can be stored as a backup or for sharing with other users.
1. Open any project page in Promis.e and click on Manage >> Catalog Manager under Catalog.
2. Select the Catalog that needs to be exported and then select Export Catalog >> Specify the Catalog Name >> Specify the Export path where the backup needs to be stored >> Select Ok to complete the processes.
| Original Author: | Satish Saptasagar |
