| Version(s): | through 08.11.13.140 | ||
| Area: | Reports_Output Features | ||
| Subarea: | Reporting |
The Panduit Labels tool generates a list of labels for wires, cables, and devices in the project. A Panduit label part number can optionally be specified so that the output will be correctly formatted for use in the Panduit Easy-Mark label-printing software.
The number of labels per wire, cable, or device can be specified.
Output can be filtered by Installation, Location, and gauge/diameter of wires/cables. Labels for devices can display the device tag or full device ID.
The list can be exported to CSV (comma separated values) format which can be opened by text editors, Excel, or other software. The list can also be sent directly to Panduit's Easy-Mark software.
See Help for details.
* is used to denote a menu selection that is not necessary in some versions or platforms.
From the Tasks area, select Output > Reports & Graphical Output > Panduit Labels
From the Tasks or ribbon area, select promis-e Output > *Reports & Graphical Output > Panduit Labels
| Original Author: | Matt_P |
