| Product(s): | ProSteel |
| Version(s): | All Versions |
| Area: | ProSteel Global Settings/Options |
| Subarea: | Loglinks tab |
| Original Author | Steffen Knoll, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
When creating a connection the dialog for the connection is not appearing.
1. Open Global Settings or Options dialog by holding right-click and then select Options from the context menu.
2. Now, go to the Loglinks page and check on "Create active logical links".
