| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | Column & Shear Wall Design | ||
Question:
We are unable to run rcdx file as we are having issue when we proceed with designing of walls. It doesn’t design concrete elements. Even when we select 2-3 walls, it crashes.
After investigating the crash issue we found that duplicate records of Column forces for C14 and C15 is found. Refer below image for better understanding of what we wrote above:
We observe that this is happening for levels up to Level 35.
We suggest that.
*Note: Before performing steps 2 and 3 mentioned above, please re-check that there is no duplicate record for Column forces at any level.
You can follow the procedure given in the below link to merge both the .mdb /accdb files in access.
