Bentley OpenUtilities Designer CONNECT Edition 10.05.00.05 Resolved Issues List:
| ID | Title |
| 419112 | Attribute Relation rules not working at point WLs |
| 419111 | Unable to create single point path in offline design |
| 415285 | Cannot remove Global attributes in Job Defaults Assistant |
| 415267 | Unknown error in Job Defaults Assistant when updating Global attribute of type STRINGVAL |
| 384392 | Edit User from admin tool causes crash |
| 365639 | Run-time error during offline design for ribbon tools Place Path and Place Point |
| 322669 | Update to Work Request may cause invalid state change |
| 322651 | Eliminate the requirement to "Run as Administrator" |
| 293083 | Refresh issue on Cancel |
| 173289 | Load, DER Primary Location, and DER Secondary Location features lacking configuration |
| 173006 | Regression of Job Defaults Assistant issue with multiple Global attributes |
| 171288 | Cannot create Custom Cost |
| 160362 | Update to work Request or Design fails |
