| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Installation | ||
| Original Author: | Global Technical Support | ||
Problem:
I am not able to Install STAAD.Pro on a machine where there is a prior version of STAAD.Pro exists. What can I do ?
Make sure Windows OS was updated followed by uninstallation of pre-existing STAAD.Pro with Connection Client. Also do not forget to uninstall any components / applications supported by Structural SELECT Entitlements. Once done, start a fresh installation.
STAAD.Pro creates a number of auxiliary data files in the same folder as the STAAD model. If any of these get corrupted or locked up, the model may fail to accept a new component(s). Sometimes these may cause the software to be crashed. These happened to a number of users, but not all.
If you still cannot install STAAD.Pro, please get in touch with Global Technical Support.
