Product: | MicroStation | ||
Version: | V8, XM, V8i, CONNECT | ||
Environment: | N\A | ||
Area: | Cells | ||
Subarea: | General |
Type 2 and Type 15 Point Cells will become a Graphic Cell with Saving to DWG Format. When saving to DWG, Point Cells "View Independent" will be converted to a Graphic Cell and the cell will become View Dependent.
This conversion from a Point cell to Graphic cell is to maintain compatibility with the DWG environment.
Original Author: | Bentley Technical Support Group |
