Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | 07.01.05.03 | ||
Environment: | N\A | ||
Area: | Text | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
When editing text, Microstation inputs edited string as new Text.
When user edits Text, MicroStation inputs edited string as new Text string. Original text string is still in file.
The 'Text Node Lock' did cause Text to disappear when it was placed. We found that this is the way the command functioned. It would not place text if there were no empty text nodes available in which to Place Text.
