| Version(s): | through 08.11.13.140 | ||
| Area: | Display | ||
| Subarea: | Display Part Numbers |
Assigned part numbers can be displayed on symbol inserted onto project pages by enabling the Display Part Numbers toggle. This is meant as a design tool and not intended for displaying part numbers on printed or published output. The PartNumber attribute that displays the part number does not need to be added to symbol definitions, this is done automatically. The Part_Part_Number attribute is not affected by the Display Part Numbers setting.
* is used to denote a menu selection that is not necessary in some versions or platforms.
The key-in toggles the display on/off.
ECAD EXEC SHOWPN
ECAD_EXEC_SHOWPN
| Original Author: | Matt_P |
Keywords: hide, visible, visibility, invisible, show, missing, drawing
