| Version(s): | 10.00.00.120+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
I went to edit my Sheet Index report from the dgnws and I received the message "Local resource, differs from library ….. .dgnlib" What does this mean and what do I need to do?
You will receive this message when a Sheet Seed dgnlib is associated to a workspace and has thus had a report library created in the dgnlib. Sheet Seed dgnlibs should not be associated to a workspace. If you receive this message...
