OpenGround Cloud Professional has the option to change the default template that will be loaded with any location type that has been defined. The default template is the template that is initially displayed when a Quick Log is produced. To change this default, firstly select the Manage Templates option from the Configuration ribbon.
The default templates window will then appear allowing for the default template to be edited. Select a new template in the drop-down list next to the location type that is to be changed and select save to close the window.
