| Version(s): | 08.00.00.00 | ||
| Area: | Custom Linestyles | ||
| Subarea: | N\A | ||
Custom Linestyles are appearing as a solid line when zoomed out of a
view when the lines are placed. If the lines are placed when the view
is zoomed in, the custom linestyle appears. Why is this happening?
Product: MicroStation
Version: V8
Area: Custom Linestyles
What is happening is that the lines may have more than 5000 iterations.
Therefore, any linestyle with more than this iteration number will
display as a single continuous line. There are a couple of ways around
this.
1. Increase the linestyle scale when placing the line.
2. Make the line length shorter
3. Use the key-in: CHANGE LINESTYLE SCALE <(><<)>scale factor> on
existing lines and have the scale factor large.
