| Version(s): | ALL |
| Area: | |
| Date Logged & Current Version | March 2020 41.04.00.013 |
What resources does fixed heat exchangers use for EN 13445 thermal expansion coefficient?
In the Material database (\Config\Material.emdm):
For a EN material, if there is no value in the table "Thermal Expansion EN Ref" the program will use by default the values entered in the Table "Thermal Expansion Ref:"
These default values come from CODAP Code.
See below an example:
Note: the Material database is a customizable file, the user can change/update the tables.
