| Version(s): | V8, V8i | ||
| Area: | Custom Line Styles | ||
| Subarea: | N\A | ||
Request for the text style to be created automatically during the import when importing .LIN custom linestyles that use a text style
within the definition.
Set the following capabilities:
CAPABILITY_LINESTYLE_CREATE_STDTXT, (enabled by default)
Allows the creation of text style Standard.
When importing linestyles from a .LIN file, if the "standard" linestyle
is needed, it will be created.
CAPAB ILITY_LINESTYLE_CREATE_TEXTSTYLE, (disabled by default)
Allows the creation of a text style of any name.
When importing line styles, if a named text style is needed, it will be
created.
Note:
-During the import process, the DWG seed file (not the transeed) will be
searched for a text style with the correct name, then use it in the
current file as the text style definition. If a matching text style
name is not found, it will create one using fairly common text style
settings.
-When the text style is created this way, the style created for
"Standard" will most likely be correct. However other styles created
this way will most likely not be correct.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108721
