| Version(s): | 08.11.09.829 | ||
| Area: | CONNECT Advisor | ||
| Subarea: | N\A |
User gets the following error message when MicroStation is started.
CONNECT Advisor: Error while processing the feature launch event.
Please download and install the latest version of CONNECT Advisor “Bentley CONNECT Advisor (MultiLanguage) 32-bit Version 08.11.09.*”
Steps for clean uninstall
• Close all Bentley Applications that are running
• From the “Programs and Features” section of the Control Panel, select CONNECT Advisor and click “Uninstall”
• On Starting uninstall, on the screen that is shown, Click Next to Continue
• A confirmation dialog will be shown, only after clicking “Uninstall”, the actual uninstallation will start
• Uninstallation of CONNECT Advisor will begin and complete.
• Reboot machine
• Install latest version of CONNECT Advisor
The uninstall and install procedure is available in the attached installer guide
