| Version: | 08.05.01.25 | ||
| Area: | Cells | ||
| Subarea: | General |
How to convert multiple V7 cell libraries to V8 cell libraries.
To convert multiple cell libraries at once, go to the Menu bar:
Element > Cells > File > Upgrade files to V8.
Select and add cell libraries to the list box and then convert.
Another option:
1. Go to Utilities > Batch Converter.
2. Select V8 file output format.
3. Select "Add files and directories to be converted" button.
4. Set search filter to "*.cel" to list only Cell libraries.
5. Select the desired cells for upgrade.
6. Hit the Add and then Done button.
7. Batch convert the selected files.
