| Product(s): | ProSteel | ||
| Area: | Steel Connections | ||
| Subarea: | Bracing Connections | ||
This wiki explains how to achieve back to back angle section in the dynamic bracing.
1. Set the required equal or unequal angle section in the Common tab of Bracing tool.
2. Now, go to the Shape Bracing tab, set the Double for the Shape Position.
In this way, we can achieve back to back angle section in the dynamic bracing.
