Master Templates and Strip Sets for Logs in HBSI
MASTER TEMPLATES
Master Templates are a way to use the same header and footer area for all your logs. They are made up of two main parts the first being the Master Template which includes the header and footer, the second is the strip set which has all the depth related information. You can have one Master Template (header and footer) and multiple strip sets show different depth related data.
How to Use a Master Template
When you go to quick log and select the Master Template you will get a header and footer showing the correct information, but the depth related area will be blank.
To get the depth area you need use the drop down below the template selection which is called Strip Sets.
How to Set Default Master Templates and Strip Sets
For quick logs you can set a Master Template to be your default for that hole type in the same way you can for traditional logs.
You will need to go to the configuration pack and manage templates button on the template part of the ribbon.
When you're in the dialog you can select the hole type you want to set the default for and select the Master Template for the drop down. You will notice that in the column next to it you have the default strip set which you can select from the drop down.
How to Set up Master Template within a Log Report
You need to go to the configuration pack and select the Report Profiles button on the templates part of the ribbon. Once in the Dialog you will need to give the report profile a name and you will get a dialog for all the hole types.
You can select the Master Template in the templates drop down. The Strip Sets drop down will become active and you can select the strip set you need.
This can be done for the scale as well as the units per page in the same way.
