| Version(s): | 22.00.00.15 and higher | ||
| Environment: | ALL | ||
| Area: | Licensing | ||
| Subarea: | N/A | ||
Description
Do I need to register to Connect services to use CONNECT version of STAAD.Pro ?
Before making use of a CONNECTED application, it is a requirement that you are registered with the CONNECT services.
Typically, your IT manager will register your company email address and will grant you access to all the services and entitlements that you should have access to. In this case you will need to sign in to Connection Client with your email and a password provided by your IT manager. Once signed in, you will have access to your CONNECT services and entitlements.
If you have not been registered, then you will need to register, details of which can be found here.
